Aller au contenu principal
Mt. Fury Roadmaster Tire Replacement
Ce dont vous avez besoin
  1. Mt. Fury Roadmaster Tire Replacement, Inner Tube: étape 1, image 1 de 1
    • Flip the bicycle upside down so that the bicycle rests on the seat and handlebars. The bike should be able to stay standing on its own.
  2. Mt. Fury Roadmaster Tire Replacement: étape 2, image 1 de 1
    • Using a 15mm wrech, loosen the axial nut.
  3. Mt. Fury Roadmaster Tire Replacement: étape 3, image 1 de 2 Mt. Fury Roadmaster Tire Replacement: étape 3, image 2 de 2
    • Pull the chain slack and remove the tire.
  4. Mt. Fury Roadmaster Tire Replacement: étape 4, image 1 de 2 Mt. Fury Roadmaster Tire Replacement: étape 4, image 2 de 2
    • Insert the flat side of the tire lever between the inside edge of the rim and the seal of the tire.
    • Clip the tire lever to the nearest spoke.
  5. Mt. Fury Roadmaster Tire Replacement: étape 5, image 1 de 2 Mt. Fury Roadmaster Tire Replacement: étape 5, image 2 de 2
    • Insert the second tire lever next to first and slowly slide it along the outside edge of the rim until one side of the tire is off the rim.
  6. Mt. Fury Roadmaster Tire Replacement: étape 6, image 1 de 1
    • Re-insert the first tire lever to hook the opposite seam of the tire and repeat steps 3 through 5.
  7. Mt. Fury Roadmaster Tire Replacement: étape 7, image 1 de 1
    • Remove the cap from the inner tube, and pull the valve stem out of the rim.
To install new inner tube, follow these instructions in reverse order.
4 autres ont terminé cette réparation.
Samantha Rawlins
Membre depuis le 01/21/14
476 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 1-40, Maness Winter 2014 Membre de l'équipe Cal Poly, Team 1-40, Maness Winter 2014
CPSU-MANESS-W14S1G40
4 membres
5 tutoriels rédigés
Un commentaire
Replace also means how to put it back together!
ellik - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 32
Total : 6,783
