Ce dont vous avez besoin
Remove twenty-four 6 mm Phillips #2 from all 6 sides.
Once the screws are removed, gently pull apart the frame.
Locate frame piece with battery pack and on-off switch, then remove two 6 mm Phillips #2 screws, located on either side of the battery pack.
Once removed, the on-off switch will easily slide out of position
Presque terminé !
