Introduction
This is the wired version of MusicAngel from a few years back.
I decided to take it apart to create this guide and see what makes it tick.
Ce dont vous avez besoin
Bottom side has 4 5.95mm tapping Phillips #1 screws, under a rubber cover.
Under the label, there are two more Phillips #1 screws 9.15mm tapping screws.
Use a very thin metal prying tool and slide it in between the metal looking grill and the speaker body. Carefully pry it out (no glue is used) all the way around.
Repeat on both speaker sides.
Use a spudger to pry the battery that is glued to the top, from the body. Note: This is pretty strong adhesive.
Tilt the speaker grill / element a little, to slide it through the body.
As you can see, there are no connectors used. All connections are soldered directly to the board.
No information can be found on the battery, either side.
The speaker elements are 45mm, 3W and 4Ω
2 autres ont terminé cette réparation.
