Introduction
Batteries power the laser. If the laser is not working, one of the reasons might be the batteries. Follow the steps in this guide to correctly replace the batteries.
Pièces
Aucune pièce nécessaire.
  1. The batteries are located in the handle of the blaster.
    • The batteries are located in the handle of the blaster.
    • The base plate is held in place with a single phillips head, 8.2 mm screw. Remove this screw and remove the base plate to access the battery compartment.
  2. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  3. Once the batteries have been removed, you can check to see if they have any charge left in them with a battery tester.
    • Once the batteries have been removed, you can check to see if they have any charge left in them with a battery tester.
    • If they are in fact dead, replace them with standard AA type batteries in the correct orientation.
Nicholas Samokyszyn
Membre depuis le 24/02/2014
338 Réputation
3 tutoriels rédigés
Équipe
Michigan Tech, Team 5-8, Lauer Spring 2014 Membre de l'équipe Michigan Tech, Team 5-8, Lauer Spring 2014
MTU-LAUER-S14S5G8
3 membres
9 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 15
Total : 1,659
