Introduction
There are many capacitors on the power supply board that control the amount of power delivered to the monitor. If a capacitor is swelling at the top or appears to have burst, it may need to be replaced.
Ce dont vous avez besoin
Place the monitor screen face up.
Pull the frame off by placing your fingers on the inside of the frame and pulling out and up, the frame should snap off.
Continue your way around the screen.
Make a note or use a pen to mark which plugs correspond to which colors. (Pink or Blue)
Remove the four plugs on the brown circuit board by pulling up on the tabs and wiggling them out. You could also use a spudger to help you lift little clips holding them in.
Outil utilisé dans cette étape :Phillips #1 Screwdriver$5.49
Locate the large black power plug.
Using a Phillips #1 Screwdriver, unscrew the two 8mm colts holding the black tabs to the metal frame.
Find the faulty capacitor on the board.
Bad capacitors can be identified by swelling or bursting at the top.
Un commentaire
Hi, the content was comprehensive. Please comment on the electrolytic capacitor . Thank you.
