Introduction
Replacing the screen isn't so much difficult as a lengthy process. There will be a lot of screws removed and a lot of parts coming off, so keep track of everything.
Place the monitor face down on a clean, flat surface.
  • Place the monitor face down on a clean, flat surface.
Ajouter un commentaire
Firmly remove the back panel of the stand by pulling it up and away from the monitor.
  • Firmly remove the back panel of the stand by pulling it up and away from the monitor.
  • Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
  • Firmly grasp the stand enclosure with your hand and slide it to base of stand.
  • Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
  • Lift the the stand straight up to remove it.
  • Place the monitor screen face up.
  • Pull the frame off by placing your fingers on the inside of the frame and pulling out and up, the frame should snap off.
  • Continue your way around the screen.
  • Unscrew the two 7mm screws from the bottom of the button assembly.
  • Do not pull the button assembly out too quickly or with too much force! Damage to the wires can occur.
  • Pull the button assembly out a few inches and unplug the colored cables.
  • Unscrew the gold colored 7mm Phillips PH000 screw holding the button assembly to the monitor.
  • Remove the button assembly from the monitor.
  • With the monitor face-down, unscrew the 5 7mm Phillips PH2 screws around the outside of the enclosure.
  • Unscrew the 2 14.5mm Phillips PH2 screws located on the raised center of the enclosure.
  • Carefully pull the enclosure off the monitor.
  • Unscrew the 10 5mm Philips PH2 screws holding the metal casing to the monitor.
  • Pull the the metal casing off of the monitor to reveal the motherboards.
  • Unplug the pink and light blue attachments from the side of the brown board by pulling up on the tabs and gently pulling the cord out.
  • Label where the plugs go.
  • Unplug the 3 multicolored cables from the blue board by gently wiggling them back and forth while pulling up.
  • Unscrew the 4 5mm Phillips PH2 screws on the sides of the monitor.
  • Begin opening the enclosure by slowing pulling up on back panel of the monitor.
  • The enclosure should still be attached by a cable; this cable is held down by tape. Remove this tape.
  • Unplug the cable from the screen. It is still attached by a fragile black belt.
  • Use a spudger to break the black ceramic belt to free the screen from the rest, allowing it to be replaced.
John Patterson
Membre depuis le 19/10/2013
217 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 11-36, Amido Fall 2013 Membre de l'équipe Cal Poly, Team 11-36, Amido Fall 2013
CPSU-AMIDO-F13S11G36
5 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 4
7 derniers jours : 5
30 derniers jours : 25
Total : 999
