Introduction
If your computer with an NZXT H510i case and an ASRock B450 Pro4 motherboard is shutting down unexpectedly or is not receiving enough power, use this guide to replace the power supply.
The power supply is what delivers power to all the other parts of the computer and is one of the fundamental components in any computer. A faulty or damaged power supply can result in a computer shutting down unexpectedly, or can result in the computer not receiving enough power to turn on.
After shutting down the computer, you will need to put on an anti-static wristband. For more information about this, and other ESD news, check out this article.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Anti-Static Wrist Strap$7.95
Drain the capacitors by pressing the power switch.
Wait several minutes after doing this to ensure that the capacitors are drained of all residual power.
Put on the anti-static wrist strap.
7 autres ont terminé cette réparation.
