Aller au contenu principal
Neato BOTVAC CONNECTED Filter Replacement
Ce dont vous avez besoin
  1. Neato BOTVAC CONNECTED Filter Replacement, Battery: étape 1, image 1 de 1
    • Place the top of the Neato Botvac Connected against a flat surface.
  2. Neato BOTVAC CONNECTED Filter Replacement: étape 2, image 1 de 2 Neato BOTVAC CONNECTED Filter Replacement: étape 2, image 2 de 2
    • Remove the two 5.5 mm screws with a Phillips #2 screwdriver.
  3. Neato BOTVAC CONNECTED Filter Replacement: étape 3, image 1 de 2 Neato BOTVAC CONNECTED Filter Replacement: étape 3, image 2 de 2
    • Using the spudger, remove the panel covering the battery.
  4. Neato BOTVAC CONNECTED Filter Replacement: étape 4, image 1 de 3 Neato BOTVAC CONNECTED Filter Replacement: étape 4, image 2 de 3 Neato BOTVAC CONNECTED Filter Replacement: étape 4, image 3 de 3
    • Gently remove the connecting wires attached to the battery.
    • The wires are attached to the vacuum through a clip.
  5. Neato BOTVAC CONNECTED Filter Replacement: étape 5, image 1 de 1
    • Using the spudger, gently remove the battery from the device.
  6. Neato BOTVAC CONNECTED Filter Replacement, Filter: étape 6, image 1 de 1
    • Flip the cleaner around and locate the front panel.
  7. Neato BOTVAC CONNECTED Filter Replacement: étape 7, image 1 de 1
    • Gently remove the front panel by opening it with a spudger.
  8. Neato BOTVAC CONNECTED Filter Replacement: étape 8, image 1 de 2 Neato BOTVAC CONNECTED Filter Replacement: étape 8, image 2 de 2
    • Use the spudger to gently remove the paper filter.
Justin Silva
Membre depuis le 03/20/23
645 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-3, Botvin Spring 2023 Membre de l'équipe UMass Dartmouth, Team 6-3, Botvin Spring 2023
UMASSD-BOTVIN-S23S6G3
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 2
Total : 59
