Aller au contenu principal
Neato BOTVAC CONNECTED Front Roller Brush Replacement
Ce dont vous avez besoin
  1. Neato BOTVAC CONNECTED Front Roller Brush Replacement, Battery: étape 1, image 1 de 1
    • Place the top of the Neato Botvac Connected against a flat surface.
  2. Neato BOTVAC CONNECTED Front Roller Brush Replacement: étape 2, image 1 de 2 Neato BOTVAC CONNECTED Front Roller Brush Replacement: étape 2, image 2 de 2
    • Remove the two 5.5 mm screws with a Phillips #2 screwdriver.
  3. Neato BOTVAC CONNECTED Front Roller Brush Replacement: étape 3, image 1 de 2 Neato BOTVAC CONNECTED Front Roller Brush Replacement: étape 3, image 2 de 2
    • Using the spudger, remove the panel covering the battery.
  4. Neato BOTVAC CONNECTED Front Roller Brush Replacement: étape 4, image 1 de 3 Neato BOTVAC CONNECTED Front Roller Brush Replacement: étape 4, image 2 de 3 Neato BOTVAC CONNECTED Front Roller Brush Replacement: étape 4, image 3 de 3
    • Gently remove the connecting wires attached to the battery.
    • The wires are attached to the vacuum through a clip.
  5. Neato BOTVAC CONNECTED Front Roller Brush Replacement: étape 5, image 1 de 1
    • Using the spudger, gently remove the battery from the device.
  6. Neato BOTVAC CONNECTED Front Roller Brush Replacement, Front Roller Brush: étape 6, image 1 de 2 Neato BOTVAC CONNECTED Front Roller Brush Replacement, Front Roller Brush: étape 6, image 2 de 2
    • Remove the following screws with a Torx screwdriver:
    • Four 2.3 mm screws.
  7. Neato BOTVAC CONNECTED Front Roller Brush Replacement: étape 7, image 1 de 1
    • Gently remove the thin panel held by the four screws with a spudger.
  8. Neato BOTVAC CONNECTED Front Roller Brush Replacement: étape 8, image 1 de 1
    • Gently remove the two small wheels, and the axles attached to them.
  9. Neato BOTVAC CONNECTED Front Roller Brush Replacement: étape 9, image 1 de 1
    • Gently remove the panel that is on top of the front roller with the spudger.
  10. Neato BOTVAC CONNECTED Front Roller Brush Replacement: étape 10, image 1 de 1
    • Gently remove the front brush.
Justin Silva
Membre depuis le 03/20/23
645 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-3, Botvin Spring 2023 Membre de l'équipe UMass Dartmouth, Team 6-3, Botvin Spring 2023
UMASSD-BOTVIN-S23S6G3
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 15
Total : 117
