Aller au contenu principal
Neato BOTVAC CONNECTED Side Wheel Replacement
Ce dont vous avez besoin
  1. Neato BOTVAC CONNECTED Side Wheel Replacement, Battery: étape 1, image 1 de 1
    • Place the top of the Neato Botvac Connected against a flat surface.
  2. Neato BOTVAC CONNECTED Side Wheel Replacement: étape 2, image 1 de 2 Neato BOTVAC CONNECTED Side Wheel Replacement: étape 2, image 2 de 2
    • Remove the two 5.5 mm screws with a Phillips #2 screwdriver.
  3. Neato BOTVAC CONNECTED Side Wheel Replacement: étape 3, image 1 de 2 Neato BOTVAC CONNECTED Side Wheel Replacement: étape 3, image 2 de 2
    • Using the spudger, remove the panel covering the battery.
  4. Neato BOTVAC CONNECTED Side Wheel Replacement: étape 4, image 1 de 3 Neato BOTVAC CONNECTED Side Wheel Replacement: étape 4, image 2 de 3 Neato BOTVAC CONNECTED Side Wheel Replacement: étape 4, image 3 de 3
    • Gently remove the connecting wires attached to the battery.
    • The wires are attached to the vacuum through a clip.
  5. Neato BOTVAC CONNECTED Side Wheel Replacement: étape 5, image 1 de 1
    • Using the spudger, gently remove the battery from the device.
  6. Neato BOTVAC CONNECTED Side Wheel Replacement, Front Roller Brush: étape 6, image 1 de 2 Neato BOTVAC CONNECTED Side Wheel Replacement, Front Roller Brush: étape 6, image 2 de 2
    • Remove the following screws with a Torx screwdriver:
    • Four 2.3 mm screws.
  7. Neato BOTVAC CONNECTED Side Wheel Replacement: étape 7, image 1 de 1
    • Gently remove the thin panel held by the four screws with a spudger.
  8. Neato BOTVAC CONNECTED Side Wheel Replacement: étape 8, image 1 de 1
    • Gently remove the two small wheels, and the axles attached to them.
  9. Neato BOTVAC CONNECTED Side Wheel Replacement: étape 9, image 1 de 1
    • Gently remove the panel that is on top of the front roller with the spudger.
  10. Neato BOTVAC CONNECTED Side Wheel Replacement: étape 10, image 1 de 1
    • Gently remove the front brush.
  11. Neato BOTVAC CONNECTED Side Wheel Replacement, Side Brush: étape 11, image 1 de 2 Neato BOTVAC CONNECTED Side Wheel Replacement, Side Brush: étape 11, image 2 de 2
    • Gently twist the side brush back and forth.
  12. Neato BOTVAC CONNECTED Side Wheel Replacement: étape 12, image 1 de 3 Neato BOTVAC CONNECTED Side Wheel Replacement: étape 12, image 2 de 3 Neato BOTVAC CONNECTED Side Wheel Replacement: étape 12, image 3 de 3
    • Spin the side brush counter counterclockwise.
  13. Neato BOTVAC CONNECTED Side Wheel Replacement: étape 13, image 1 de 1
    • Use the spudger to gently pry up and remove the side brush.
  14. Neato BOTVAC CONNECTED Side Wheel Replacement, Filter: étape 14, image 1 de 1
    • Flip the cleaner around and locate the front panel.
  15. Neato BOTVAC CONNECTED Side Wheel Replacement: étape 15, image 1 de 1
    • Gently remove the front panel by opening it with a spudger.
  16. Neato BOTVAC CONNECTED Side Wheel Replacement: étape 16, image 1 de 2 Neato BOTVAC CONNECTED Side Wheel Replacement: étape 16, image 2 de 2
    • Use the spudger to gently remove the paper filter.
  17. Neato BOTVAC CONNECTED Side Wheel Replacement, Side Wheel: étape 17, image 1 de 1
    • Remove the following screws with a TR10 Torx screwdriver:
    • Six 2.3 mm screws.
  18. Neato BOTVAC CONNECTED Side Wheel Replacement: étape 18, image 1 de 2 Neato BOTVAC CONNECTED Side Wheel Replacement: étape 18, image 2 de 2
    • Remove the front bumper by pulling it horizontally on each side.
  19. Neato BOTVAC CONNECTED Side Wheel Replacement: étape 19, image 1 de 1
    • Remove the screw that is directly attached to the wheel on the side using a Phillips #2 screwdriver.
  20. Neato BOTVAC CONNECTED Side Wheel Replacement: étape 20, image 1 de 1
    • Remove the two 2.3 mm screws on the front of the vacuum with a TR10 Torx screwdriver.
  21. Neato BOTVAC CONNECTED Side Wheel Replacement: étape 21, image 1 de 1
    • Remove the layer below the front bumper by pressing firmly on the two levers located nearby.
  22. Neato BOTVAC CONNECTED Side Wheel Replacement: étape 22, image 1 de 3 Neato BOTVAC CONNECTED Side Wheel Replacement: étape 22, image 2 de 3 Neato BOTVAC CONNECTED Side Wheel Replacement: étape 22, image 3 de 3
    • Gently take out the top panel, and take out the connecting wires.
  23. Neato BOTVAC CONNECTED Side Wheel Replacement: étape 23, image 1 de 1
    • Two 2.3 mm screws.
  24. Neato BOTVAC CONNECTED Side Wheel Replacement: étape 24, image 1 de 1
    • Flip around the vacuum and remove the wheel with the spudger.
Justin Silva
Membre depuis le 03/20/23
645 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-3, Botvin Spring 2023 Membre de l'équipe UMass Dartmouth, Team 6-3, Botvin Spring 2023
UMASSD-BOTVIN-S23S6G3
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 6
30 derniers jours : 18
Total : 239
