Aller au contenu principal
Neato Botvac Connected Screen Replacement
Ce dont vous avez besoin
  1. Neato Botvac Connected Screen Replacement, Screen: étape 1, image 1 de 3 Neato Botvac Connected Screen Replacement, Screen: étape 1, image 2 de 3 Neato Botvac Connected Screen Replacement, Screen: étape 1, image 3 de 3
    • Flip the Botvac over so that the underside is facing up and the flat front is facing toward you.
    • Remove the four screws lining the front roller using a TR10 Torx screwdriver.
    • Remove the black panel behind and in front of the roller.
    • Gently lift the roller by the right side to remove it.
  2. Neato Botvac Connected Screen Replacement: étape 2, image 1 de 1
    • Remove the two screws behind the front roller of the robot using a Phillips #2 screwdriver.
    • Remove the battery by lifting it out while pressing down on the wire clip inside the compartment.
  3. Neato Botvac Connected Screen Replacement: étape 3, image 1 de 3 Neato Botvac Connected Screen Replacement: étape 3, image 2 de 3 Neato Botvac Connected Screen Replacement: étape 3, image 3 de 3
    • Pull one side of the front bumper out and then forward toward you. Repeat on the other side to completely detach the front bumper.
  4. Neato Botvac Connected Screen Replacement: étape 4, image 1 de 2 Neato Botvac Connected Screen Replacement: étape 4, image 2 de 2
    • Remove the eight screws from the underside of the Botvac using a TR10 Torx screwdriver.
    • Remove the additional two TR10 screws from the top of the Botvac.
    • Remove the dustbin.
  5. Neato Botvac Connected Screen Replacement: étape 5, image 1 de 3 Neato Botvac Connected Screen Replacement: étape 5, image 2 de 3 Neato Botvac Connected Screen Replacement: étape 5, image 3 de 3
    • Pry the clips on the front of the robot apart.
    • Unplug the beige connector with a spudger, working one side at a time until it comes unplugged.
    • Make certain not to not to tear any wires out of the port.
    • Lay the top of the robot inside up.
  6. Neato Botvac Connected Screen Replacement: étape 6, image 1 de 2 Neato Botvac Connected Screen Replacement: étape 6, image 2 de 2
    • Unplug the beige connector with a spudger. Be careful not to tear out any wires.
    • Remove the two screws from the screen using a TR10 Torx screwdriver.
    • Remove the screen from the vacuum.
Jerome
Membre depuis le 03/01/23
365 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 117
