Aller au contenu principal
Neato XV-21 Wheels Replacement
Ce dont vous avez besoin
  1. Neato XV-21 Wheels Replacement, Back Panels of Neato XV-21: étape 1, image 1 de 1
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
  2. Neato XV-21 Wheels Replacement: étape 2, image 1 de 1
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. Neato XV-21 Wheels Replacement: étape 3, image 1 de 1
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Neato XV-21 Wheels Replacement, Battery: étape 4, image 1 de 1
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
  5. Neato XV-21 Wheels Replacement, Wheels: étape 5, image 1 de 1
    • Pinch and pull the white connector, indicated in the image, to disconnect the wheel from the robot. Repeat for both wheels
  6. Neato XV-21 Wheels Replacement: étape 6, image 1 de 1
    • Slide out dowel rod connecting the wheel to the robot.
  7. Neato XV-21 Wheels Replacement: étape 7, image 1 de 2 Neato XV-21 Wheels Replacement: étape 7, image 2 de 2
    • Lift the wheel so the spring is exposed
    • Pay particular attention to how the wheel is placed to replicate during reinsertion
    • Unhook the spring from robot
    • Lift the wheel from the cavity
3 autres ont terminé cette réparation.
zachary rodriguez
Membre depuis le 09/25/17
107 Réputation
1 tutoriel rédigé
Équipe
Un commentaire
Needs to Link to Parts List and a way to Order Parts.
Bill Price - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 699
