Aller au contenu principal
Nerf Alpha Trooper CS-18 Hammer Rod Replacement
Ce dont vous avez besoin
  1. Nerf Alpha Trooper CS-18 Hammer Rod Replacement, Plunger: étape 1, image 1 de 1
    • It is important to group screws together by length to ensure proper reassembly.
    • Be sure that the device has been discharged and is unloaded before beginning the repair process.
  2. Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 2, image 1 de 3 Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 2, image 2 de 3 Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 2, image 3 de 3
    • Look at the rear of the rifle. Remove the two 10 mm Phillips head screws that hold the black cap to the rear of the rifle.
    • Gently remove the black cap.
  3. Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 3, image 1 de 2 Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 3, image 2 de 2
    • Point the barrel of the device to the left, screw side up. Remove the two 8 mm Phillips head screws (the top two) holding the device slide together.
    • Keep the device in the same position, remove the three 10 mm Phillips head screws from the bottom of the device slide.
    • Once all screws are removed, carefully separate the two halves of the device slide and put them aside.
    • Be sure to keep track of which screws correspond to the correct holes.
  4. Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 4, image 1 de 3 Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 4, image 2 de 3 Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 4, image 3 de 3
    • Keeping the barrel in the same position as step 3, remove the fourteen 10 mm Phillips head screws from the body of the device.
    • With the device in the same position, remove the 4 remaining 5 mm Phillips head screws from the body of the device.
    • Screws vary in lengths. Be sure to keep track of which screws correspond to the correct holes.
  5. Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 5, image 1 de 3 Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 5, image 2 de 3 Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 5, image 3 de 3
    • Grip the cartridge insert, and pull the two halves of the device apart.
    • Warning! The firing spring is not fastened to the device. It and other small parts may fall out of the device when separating it.
    • If you are having difficulty separating the two halves of the device, use a spudger to pry the two halves apart.
    • Remove the access gate and barrel cover.
  6. Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 6, image 1 de 1
    • Now remove the main firing spring from the rear of the device by gently pulling it.
  7. Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 7, image 1 de 2 Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 7, image 2 de 2
    • Slide the plunger lock back away from the device, then lift out towards yourself to remove.
    • Be careful not to lose the small spring on the top of the plunger lock.
  8. Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 8, image 1 de 1
    • Pull plunger away in the same motion as in step 7 with the plunger lock.
  9. Nerf Alpha Trooper CS-18 Hammer Rod Replacement, Hammer Rod: étape 9, image 1 de 1
    • Remove the two 5 mm Phillips #0 screws holding the muzzle in place.
  10. Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 10, image 1 de 1
    • Remove the barrel and muzzle assembly from the gun body.
  11. Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 11, image 1 de 1
    • Remove the 5 mm Phillips #0 screw holding in the chamber lock mechanism.
  12. Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 12, image 1 de 3 Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 12, image 2 de 3 Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 12, image 3 de 3
    • Pull the front chamber lock spring out of its seat.
    • Pull the front chamber lock down and out of the rifle barrel.
    • There are two pieces to this mechanism.
  13. Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 13, image 1 de 2 Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 13, image 2 de 2
    • Hold down the spring that locks the chamber to the forward position, then slide the chamber to the rear of the rifle.
    • Remove front barrel guide.
  14. Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 14, image 1 de 2 Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 14, image 2 de 2
    • Push the barrel forward and remove the square piece that holds the back of the barrel in place.
  15. Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 15, image 1 de 1
    • Pull the air cylinder and plunger assembly out of the rifle.
  16. Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 16, image 1 de 2 Nerf Alpha Trooper CS-18 Hammer Rod Replacement: étape 16, image 2 de 2
    • Hold the slide lock down and pull the bullet chamber assembly up and out of the rifle.
    • Part of the magazine lock mechanism should come along with it.
    • The hammer rod mechanism is flipped over in the second picture. The rod should face the front of the gun with the screw facing down.
    • Remove the screw and replace the hammer rod.
Christian Getsinger
Membre depuis le 02/03/16
131 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 950
