Aller au contenu principal
Nerf Dart Tag Furyfire Large Spring Replacement
Ce dont vous avez besoin
  1. Nerf Dart Tag Furyfire Large Spring Replacement, Remove the screws: étape 1, image 1 de 1
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Panel: étape 2, image 1 de 1
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Black Cylinder: étape 3, image 1 de 1
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Spring: étape 4, image 1 de 2 Nerf Dart Tag Furyfire Large Spring Replacement, Remove Spring: étape 4, image 2 de 2
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
Bradley Penrow
Membre depuis le 09/23/14
37 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 11-2, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 11-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 18
Total : 1,422
