Aller au contenu principal
Nerf Dart Tag Furyfire Pump Track Replacement
Ce dont vous avez besoin
  1. Nerf Dart Tag Furyfire Pump Track Replacement, Remove the screws: étape 1, image 1 de 1
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Panel: étape 2, image 1 de 1
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Black Cylinder: étape 3, image 1 de 1
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Spring: étape 4, image 1 de 2 Nerf Dart Tag Furyfire Pump Track Replacement, Remove Spring: étape 4, image 2 de 2
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
  5. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Pump Handle: étape 5, image 1 de 1
    • Remove the two screws circled in blue. They are .95 cm in length.
    • Remove the three screw circled in green. They are .7 cm in length.
  6. Nerf Dart Tag Furyfire Pump Track Replacement, Remove the Pump Handle: étape 6, image 1 de 1
    • Once all of the screws have been removed lift the pump handle off and set it aside.
  7. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Attached Spring: étape 7, image 1 de 2 Nerf Dart Tag Furyfire Pump Track Replacement, Remove Attached Spring: étape 7, image 2 de 2
    • In order to remove the white plastic holder, you must remove the spring that keeps it in place. Using a 00 Phillips screwdriver, carefully remove the screw while holding the spring in place.
  8. Nerf Dart Tag Furyfire Pump Track Replacement, Disengage White Piece: étape 8, image 1 de 1
    • Using a plastic opening tool, lift the white piece out of the gun and set it aside.
  9. Nerf Dart Tag Furyfire Pump Track Replacement, Remove the Pump Track: étape 9, image 1 de 2 Nerf Dart Tag Furyfire Pump Track Replacement, Remove the Pump Track: étape 9, image 2 de 2
    • Using your hand, slide the track out of the gun by pulling it away form the device.
Bradley Penrow
Membre depuis le 09/23/14
37 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 11-2, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 11-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 459
