Aller au contenu principal
Nerf Dart Tag Swarmfire Motor Spring Replacement
Ce dont vous avez besoin
  1. Nerf Dart Tag Swarmfire Motor Spring Replacement, Motor Spring Replacement: étape 1, image 1 de 2 Nerf Dart Tag Swarmfire Motor Spring Replacement, Motor Spring Replacement: étape 1, image 2 de 2
    • Using the JIS #1 screwdriver, loosen the nine screws, holding the outer yellow shell in place
    • The screwdriver you'll be using is a J1 head from the 64 Bit Kit.
    • Be sure to sure to use the Magnetic Project Mat to prevent loss of the screws.
  2. Nerf Dart Tag Swarmfire Motor Spring Replacement: étape 2, image 1 de 1
    • Lift off the outer yellow shell.
  3. Nerf Dart Tag Swarmfire Motor Spring Replacement: étape 3, image 1 de 3 Nerf Dart Tag Swarmfire Motor Spring Replacement: étape 3, image 2 de 3 Nerf Dart Tag Swarmfire Motor Spring Replacement: étape 3, image 3 de 3
    • Remove the screw holding the battery compartment shut.
    • Lift off the inner blue casing
  4. Nerf Dart Tag Swarmfire Motor Spring Replacement: étape 4, image 1 de 3 Nerf Dart Tag Swarmfire Motor Spring Replacement: étape 4, image 2 de 3 Nerf Dart Tag Swarmfire Motor Spring Replacement: étape 4, image 3 de 3
    • Lift off the blue casing, exposing the white motor spring compartment.
    • Loosen and remove the three screws holding the white compartment door shut.
  5. Nerf Dart Tag Swarmfire Motor Spring Replacement: étape 5, image 1 de 2 Nerf Dart Tag Swarmfire Motor Spring Replacement: étape 5, image 2 de 2
    • Unsnap the white compartment into two pieces.
  6. Nerf Dart Tag Swarmfire Motor Spring Replacement: étape 6, image 1 de 3 Nerf Dart Tag Swarmfire Motor Spring Replacement: étape 6, image 2 de 3 Nerf Dart Tag Swarmfire Motor Spring Replacement: étape 6, image 3 de 3
    • Remove the motor spring located inside the rotating barrel and replace.
Sonal Purohit
Membre depuis le 07/25/16
115 Réputation
1 tutoriel rédigé
Équipe
University of Memphis, Team 2-3, Kim SU 2016 Membre de l'équipe University of Memphis, Team 2-3, Kim SU 2016
UM-KIM-SU16S2G3
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 4
Total : 856
