Aller au contenu principal
Nerf Dart Tag Swarmfire Trigger Spring Replacement
Ce dont vous avez besoin
  1. Nerf Dart Tag Swarmfire Trigger Spring Replacement, Trigger Spring: étape 1, image 1 de 2 Nerf Dart Tag Swarmfire Trigger Spring Replacement, Trigger Spring: étape 1, image 2 de 2
    • Place the blaster on its side with the handle to the right and loosen all screws so the shell can be opened. (Not all screws are visible in the provided pictures.)
    • Avoid the fake plastic screw, which is merely decorative.
  2. Nerf Dart Tag Swarmfire Trigger Spring Replacement: étape 2, image 1 de 3 Nerf Dart Tag Swarmfire Trigger Spring Replacement: étape 2, image 2 de 3 Nerf Dart Tag Swarmfire Trigger Spring Replacement: étape 2, image 3 de 3
    • Gently remove the yellow and grey shell pieces from the blaster to display the blaster's motherboards and motor.
    • Do not force the shell open. If it does not come off easily, repeat step 1 and ensure all screws are loose.
  3. Nerf Dart Tag Swarmfire Trigger Spring Replacement: étape 3, image 1 de 2 Nerf Dart Tag Swarmfire Trigger Spring Replacement: étape 3, image 2 de 2
    • Locate the orange trigger (dark blue if it's the newer version).
    • Slide the trigger out of place and check the spring. It should be corrosion-free and fitted to the knob on the back of the trigger.
    • It's important to check the spring for damage before removing it to prevent injuries.
  4. Nerf Dart Tag Swarmfire Trigger Spring Replacement: étape 4, image 1 de 2 Nerf Dart Tag Swarmfire Trigger Spring Replacement: étape 4, image 2 de 2
    • If it is damaged, pull the spring off the trigger, then push the replacement spring onto the knob so it catches and doesn't fall off.
    • If the spring is not damaged, it is possible the spring was installed incorrectly. Ensure the spring is attached to the knob so it sticks straight out and doesn't fall off.
  5. Nerf Dart Tag Swarmfire Trigger Spring Replacement: étape 5, image 1 de 3 Nerf Dart Tag Swarmfire Trigger Spring Replacement: étape 5, image 2 de 3 Nerf Dart Tag Swarmfire Trigger Spring Replacement: étape 5, image 3 de 3
    • Put the trigger back into place with the trigger spring pressed into the small slot behind the trigger well. It should fit into place straight with slight compression.
    • It is helpful to test the trigger at this stage by holding it against the shell and sliding it back and forth. A correctly reinstalled spring will not pop out of the slot.
To reassemble the blaster, replace the shell pieces from innermost to outer and gently tighten the screws until they give a little resistance. If the screws give significant resistance initially, back them up and loosely turn them until they screw in with little effort.
Ashely Janae Wodall
Membre depuis le 07/20/16
242 Réputation
2 tutoriels rédigés
Équipe
University of Memphis, Team 2-3, Kim SU 2016 Membre de l'équipe University of Memphis, Team 2-3, Kim SU 2016
UM-KIM-SU16S2G3
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 7
Total : 631
