Aller au contenu principal
Nerf Mega Magnus Spring Replacement
Ce dont vous avez besoin
  1. Nerf Mega Magnus Spring Replacement, Spring: étape 1, image 1 de 3 Nerf Mega Magnus Spring Replacement, Spring: étape 1, image 2 de 3 Nerf Mega Magnus Spring Replacement, Spring: étape 1, image 3 de 3
    • Start by removing the (4) exterior Phillips screws from the shell of the gun with a #1 Phillips Screwdriver.
  2. Nerf Mega Magnus Spring Replacement: étape 2, image 1 de 2 Nerf Mega Magnus Spring Replacement: étape 2, image 2 de 2
    • Pulling upward from the rest of the shell, carefully remove the half of the slide facing you.
  3. Nerf Mega Magnus Spring Replacement: étape 3, image 1 de 3 Nerf Mega Magnus Spring Replacement: étape 3, image 2 de 3 Nerf Mega Magnus Spring Replacement: étape 3, image 3 de 3
    • On the same side, remove all (9) screws from the body of the blaster as shown.
  4. Nerf Mega Magnus Spring Replacement: étape 4, image 1 de 2 Nerf Mega Magnus Spring Replacement: étape 4, image 2 de 2
    • Lift up on the top half of the shell with deliberate force. This should reveal the internals.
  5. Nerf Mega Magnus Spring Replacement: étape 5, image 1 de 3 Nerf Mega Magnus Spring Replacement: étape 5, image 2 de 3 Nerf Mega Magnus Spring Replacement: étape 5, image 3 de 3
    • Remove the screws from the trigger mechanism and lift it upward
  6. Nerf Mega Magnus Spring Replacement: étape 6, image 1 de 2 Nerf Mega Magnus Spring Replacement: étape 6, image 2 de 2
    • Locate the small grey piece under the plunger tube and remove the screw.
  7. Nerf Mega Magnus Spring Replacement: étape 7, image 1 de 3 Nerf Mega Magnus Spring Replacement: étape 7, image 2 de 3 Nerf Mega Magnus Spring Replacement: étape 7, image 3 de 3
    • Locate the screws on the return spring. Using a counterclockwise rotation, remove both of the screws.
  8. Nerf Mega Magnus Spring Replacement: étape 8, image 1 de 2 Nerf Mega Magnus Spring Replacement: étape 8, image 2 de 2
    • Using a small tool, carefully remove the spring from its pegs.
  9. Nerf Mega Magnus Spring Replacement: étape 9, image 1 de 3 Nerf Mega Magnus Spring Replacement: étape 9, image 2 de 3 Nerf Mega Magnus Spring Replacement: étape 9, image 3 de 3
    • Locate the screws behind the dart pusher mechanism. Carefully remove each screw.
  10. Nerf Mega Magnus Spring Replacement: étape 10, image 1 de 3 Nerf Mega Magnus Spring Replacement: étape 10, image 2 de 3 Nerf Mega Magnus Spring Replacement: étape 10, image 3 de 3
    • Pull upwards on the dart pusher and spring to remove them.
  11. Nerf Mega Magnus Spring Replacement: étape 11, image 1 de 2 Nerf Mega Magnus Spring Replacement: étape 11, image 2 de 2
    • Lift up on the magazine plate in order to remove it.
  12. Nerf Mega Magnus Spring Replacement: étape 12, image 1 de 3 Nerf Mega Magnus Spring Replacement: étape 12, image 2 de 3 Nerf Mega Magnus Spring Replacement: étape 12, image 3 de 3
    • Pull upward on the dart lip and it will lift off.
  13. Nerf Mega Magnus Spring Replacement: étape 13, image 1 de 3 Nerf Mega Magnus Spring Replacement: étape 13, image 2 de 3 Nerf Mega Magnus Spring Replacement: étape 13, image 3 de 3
    • Lift the left side of the plunger tube from its peg and the rest will slide off the spring peg.
  14. Nerf Mega Magnus Spring Replacement: étape 14, image 1 de 3 Nerf Mega Magnus Spring Replacement: étape 14, image 2 de 3 Nerf Mega Magnus Spring Replacement: étape 14, image 3 de 3
    • Slide the spring off its peg. If the spring is damaged, replace it.
3 autres ont terminé cette réparation.
Averi Fletcher
Membre depuis le 06/01/16
147 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 22
Total : 3,605
