Aller au contenu principal
Nerf N-Strike Elite Hail-Fire Battery Replacement
Ce dont vous avez besoin
  1. Nerf N-Strike Elite Hail-Fire Battery Replacement, Battery: étape 1, image 1 de 1
    • Remove the two 9.0 mm Phillips screws from the battery compartment.
  2. Nerf N-Strike Elite Hail-Fire Battery Replacement: étape 2, image 1 de 1
    • Pull the battery compartment out and away from the gun.
  3. Nerf N-Strike Elite Hail-Fire Battery Replacement: étape 3, image 1 de 1
    • Apply downwards pressure on the battery you're trying to remove in the direction of the spring.
  4. Nerf N-Strike Elite Hail-Fire Battery Replacement: étape 4, image 1 de 1
    • Pull battery straight out. Do not throw used batteries in the trash! Please electronically recycle them properly.
  5. Nerf N-Strike Elite Hail-Fire Battery Replacement: étape 5, image 1 de 1
    • When installing new batteries, ensure that their polarities are facing the correct directions. Follow the inscriptions on the bottom of the battery tray, or place the flat side of each battery against the spring.
6 autres ont terminé cette réparation.
Jonathan Peck
Membre depuis le 01/24/14
217 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 13-13, Regan Winter 2014 Membre de l'équipe Cal Poly, Team 13-13, Regan Winter 2014
CPSU-REGAN-W14S13G13
4 membres
7 tutoriels rédigés
Un commentaire
thanks it works
unturned lore - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 17
30 derniers jours : 97
Total : 25,644
