Aller au contenu principal
Nerf N-Strike Elite Retaliator Barrel Replacement
Ce dont vous avez besoin
  1. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Barrel: étape 1, image 1 de 1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Grip: étape 2, image 1 de 1
    • Slide the hand grip assembly toward the end of the barrel and off the barrel assembly.
    • This may require more force than anticipated.
  3. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Barrel Cap: étape 3, image 1 de 1
    • Disassemble the orange barrel cap by removing two 8mm Phillips screws.
  4. Nerf N-Strike Elite Retaliator  Barrel Replacement, Disassemble Barrel Assembly: étape 4, image 1 de 1
    • Disassemble the barrel assembly by removing four 8mm Phillips screws from the blue barrel housing.
    • There are springs that may become displaced when the barrel housing is removed. Proceed with caution.
  5. Nerf N-Strike Elite Retaliator  Barrel Replacement, Replace Barrel: étape 5, image 1 de 1
    • Remove the orange barrel from the assembly.
6 autres ont terminé cette réparation.
ericharman
Membre depuis le 03/02/16
1 410 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 32
Total : 11,490
