Aller au contenu principal
Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement
Ce dont vous avez besoin
  1. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement, Case Disassembly: étape 1, image 1 de 1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: étape 2, image 1 de 1
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
  3. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: étape 3, image 1 de 1
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
  4. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: étape 4, image 1 de 2 Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: étape 4, image 2 de 2
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
  5. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: étape 5, image 1 de 2 Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: étape 5, image 2 de 2
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
  6. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement, Air Chamber: étape 6, image 1 de 1
    • The firing spring may be energized. If so, carefully release and spring pressure before proceeding.
    • While holding down the white air chamber, pull the firing spring backwards to remove it from the blaster.
  7. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: étape 7, image 1 de 1
    • Slide the white air chamber forward and remove the white alignment bracket.
  8. Nerf N-Strike Elite Retaliator Air Chamber Assembly Replacement: étape 8, image 1 de 1
    • Remove white air chamber by depressing the orange trigger apparatus and pulling backwards off of the barrel.
16 autres ont terminé cette réparation.
ericharman
Membre depuis le 03/02/16
1 410 Réputation
5 tutoriels rédigés
4 commentaires
Where did we found the pièces??
Albert Einstein - Réponse
where i can buy for spare part “air chamber”?
sabeni83_king - Réponse
this tutorial helped A LOT
Daniel MacDonald - Réponse
OK I've removed the air chamber now what?
camper234 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 41
Total : 19,997
