Introduction
A worn plunging mechanism can limit your effective firing range. Nobody has time for that. Use this guide to disassemble the blaster and replace the plunger and air chamber.
Ce dont vous avez besoin
While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
While holding down the white air chamber, pull the firing spring backwards to remove it from the blaster.
16 autres ont terminé cette réparation.
4 commentaires
Where did we found the pièces??
where i can buy for spare part “air chamber”?
this tutorial helped A LOT
