Introduction
Moving components in your blaster can be accessed by removing the outer casing. This guide shows how to access these inner components.
Ce dont vous avez besoin
While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
28 autres ont terminé cette réparation.
15 commentaires
How do I clean the slider track?
you probably should not do that. i think its oily for a reason.
You shouldn't. That oily substance is lubricant, which is crucial for smooth functionality.
SirMikay -
Mine had a chopped off dart head stuck in the trigger mechanism.
I had to partially disassemble in order to be able to free the slide which was covering 1 screw.
Overall, it was very easy. Only challenge is keeping track of the screws, as they're not all the same.
Leave the screws in the casing
