Aller au contenu principal
Nerf N-Strike Elite Strongarm Main Spring Replacement
Ce dont vous avez besoin
  1. Nerf N-Strike Elite Strongarm Main Spring Replacement, Main Spring: étape 1, image 1 de 1
    • Remove the outside cover of the Nerf gun (cover and charging slide, 12 Phillips #0 screws).
  2. Nerf N-Strike Elite Strongarm Main Spring Replacement: étape 2, image 1 de 1
    • From the base, lift the action and the trigger.
  3. Nerf N-Strike Elite Strongarm Main Spring Replacement: étape 3, image 1 de 1
    • Lift the Nerf dart cylinder and the firing mechanism (spring chamber).
  4. Nerf N-Strike Elite Strongarm Main Spring Replacement: étape 4, image 1 de 3 Nerf N-Strike Elite Strongarm Main Spring Replacement: étape 4, image 2 de 3 Nerf N-Strike Elite Strongarm Main Spring Replacement: étape 4, image 3 de 3
    • Unscrew screws (2) from the cylinder rotator mechanism.
  5. Nerf N-Strike Elite Strongarm Main Spring Replacement: étape 5, image 1 de 1
    • Remove the air plunger and the spring from inside the chamber.
  6. Nerf N-Strike Elite Strongarm Main Spring Replacement: étape 6, image 1 de 3 Nerf N-Strike Elite Strongarm Main Spring Replacement: étape 6, image 2 de 3 Nerf N-Strike Elite Strongarm Main Spring Replacement: étape 6, image 3 de 3
    • Turn the spring counter-clockwise to free the spring. Be careful at the beginning and the end of the process.
  7. Nerf N-Strike Elite Strongarm Main Spring Replacement: étape 7, image 1 de 3 Nerf N-Strike Elite Strongarm Main Spring Replacement: étape 7, image 2 de 3 Nerf N-Strike Elite Strongarm Main Spring Replacement: étape 7, image 3 de 3
    • Replace the spring.
    • The spring will be greasy. Don’t be alarmed. Be careful at the beginning and the end of the process because it is like getting a key ring on at the notches, particularly at the top of the chamber.
    • Tip: If dry, use a little vegetable oil on the O-ring before putting it back.
  8. Nerf N-Strike Elite Strongarm Main Spring Replacement: étape 8, image 1 de 1
    • Return the plunger to the spring chamber.
  9. Nerf N-Strike Elite Strongarm Main Spring Replacement: étape 9, image 1 de 2 Nerf N-Strike Elite Strongarm Main Spring Replacement: étape 9, image 2 de 2
    • Screw the cover back onto the cylinder rotator.
  10. Nerf N-Strike Elite Strongarm Main Spring Replacement: étape 10, image 1 de 1
    • Place the spring chamber and the Nerf bullet cylinder back into the base.
  11. Nerf N-Strike Elite Strongarm Main Spring Replacement: étape 11, image 1 de 2 Nerf N-Strike Elite Strongarm Main Spring Replacement: étape 11, image 2 de 2
    • Screw the trigger and the action back in. Swing the gray gun charging slide out when putting the action back in.
  12. Nerf N-Strike Elite Strongarm Main Spring Replacement: étape 12, image 1 de 1
    • Secure the cover and the charging slide with the 12 screws.
5 autres ont terminé cette réparation.
Robert
Membre depuis le 03/18/15
192 Réputation
1 tutoriel rédigé
4 commentaires
Where can I buy a replacement spring?
mike580358 - Réponse
you can get a replacement or an upgrade spring at the website www.nfstrike.com
NEW CHANNEL -
When I put it back together it did not work
autisteck - Réponse
My kid got sand in this blaster and i was tasked with fixing. i degreased the parts and used a plastic grease to re lube, but it was too thick for the plunger so the darts limped out the barrel. so i opened it up and used some fogging oil in there after cleaning it out. works a treat. The biggest problem was the little spring on the barrel.. I lost it 4 times, and the fifth it was gone. So i used a spring from a clicky pen and it works great now!
tiderfish - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 53
Total : 16,280
