Aller au contenu principal
Nerf N-Strike Elite Strongarm Trigger Mechanism Replacement
Ce dont vous avez besoin
  1. Nerf N-Strike Elite Strongarm Trigger Mechanism Replacement, Outer Shell: étape 1, image 1 de 2 Nerf N-Strike Elite Strongarm Trigger Mechanism Replacement, Outer Shell: étape 1, image 2 de 2
    • Lay the Nerf Strongarm on its side, left side facing up.
  2. Nerf N-Strike Elite Strongarm Trigger Mechanism Replacement: étape 2, image 1 de 2 Nerf N-Strike Elite Strongarm Trigger Mechanism Replacement: étape 2, image 2 de 2
    • Locate the 12 Philips head screws and remove them: Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
  3. Nerf N-Strike Elite Strongarm Trigger Mechanism Replacement: étape 3, image 1 de 1
    • Before removing the cover, make sure to first remove the cover for the cocking mechanism. The top half is freely removable.
    • The other half of the cocking mechanism is connected with a spring which may slide off the blaster. Be advised this is normal but worth watching to avoid damaging the spring.
  4. Nerf N-Strike Elite Strongarm Trigger Mechanism Replacement: étape 4, image 1 de 1
    • At this time, remove the blaster cover to reveal its internals.
    • If the blaster is resting on its side, the barrel may shift slightly as it is leaning on itself (seen in the image). This is normal but should be handled with care to keep the blaster together.
  5. Nerf N-Strike Elite Strongarm Trigger Mechanism Replacement: étape 5, image 1 de 1
    • Once the screws have been removed, lift the top half of the gun off.
    • Notice, the gray colored piece must be removed first in order for the larger half to be removed.
    • Take care and try not to lose any smaller pieces as you open it up.
    • Locking tab for attachments.
  6. Nerf N-Strike Elite Strongarm Trigger Mechanism Replacement, Trigger Mechanism: étape 6, image 1 de 2 Nerf N-Strike Elite Strongarm Trigger Mechanism Replacement, Trigger Mechanism: étape 6, image 2 de 2
    • Locate the trigger mechanism's assembly, and notice that it's held in place by a single philip's head screw. Remove it.
    • Screw specifications: Philips head, Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
  7. Nerf N-Strike Elite Strongarm Trigger Mechanism Replacement: étape 7, image 1 de 3 Nerf N-Strike Elite Strongarm Trigger Mechanism Replacement: étape 7, image 2 de 3 Nerf N-Strike Elite Strongarm Trigger Mechanism Replacement: étape 7, image 3 de 3
    • Inspect the orange parts for signs of damage and debris. Any broken pieces must be replaced.
    • This is the spring that controls the trigger. Through regular use, the spring may become mangled or damaged. If it becomes damaged, a spring from a ballpoint pen can function as a decent replacement.
9 autres ont terminé cette réparation.
Alexander Kim
Membre depuis le 08/27/15
832 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 5-4, Blackwell Fall 2015 Membre de l'équipe USF Tampa, Team 5-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G4
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 11
30 derniers jours : 50
Total : 21,561
