Aller au contenu principal
Nerf N-Strike Firestrike Firing Trigger Replacement
Ce dont vous avez besoin
  1. Nerf N-Strike Firestrike Firing Trigger Replacement, Remove battery cover: étape 1, image 1 de 1
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
  2. Nerf N-Strike Firestrike Firing Trigger Replacement: étape 2, image 1 de 2 Nerf N-Strike Firestrike Firing Trigger Replacement: étape 2, image 2 de 2
    • Slide out the two AAA batteries using your fingers.
  3. Nerf N-Strike Firestrike Firing Trigger Replacement, Blaster Casing: étape 3, image 1 de 1
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
  4. Nerf N-Strike Firestrike Firing Trigger Replacement: étape 4, image 1 de 2 Nerf N-Strike Firestrike Firing Trigger Replacement: étape 4, image 2 de 2
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
  5. Nerf N-Strike Firestrike Firing Trigger Replacement: étape 5, image 1 de 2 Nerf N-Strike Firestrike Firing Trigger Replacement: étape 5, image 2 de 2
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
  6. Nerf N-Strike Firestrike Firing Trigger Replacement, Firing Trigger: étape 6, image 1 de 2 Nerf N-Strike Firestrike Firing Trigger Replacement, Firing Trigger: étape 6, image 2 de 2
    • Remove the firing trigger by grabbing the trigger with your fingers and pulling it up and out.
4 autres ont terminé cette réparation.
Jong Wan Kim
Membre depuis le 04/22/15
422 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 15-6, Amido Spring 2015 Membre de l'équipe Cal Poly, Team 15-6, Amido Spring 2015
CPSU-AMIDO-S15S15G6
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 16
Total : 3,000
