Aller au contenu principal
Nerf N-Strike Maverick Trigger Repair
Ce dont vous avez besoin
  1. Nerf N-Strike Maverick Trigger Repair, Nerf N-Strike Maverick Trigger Repair: étape 1, image 1 de 1
    • Remove the 10 screws on the outer shell of the Maverick.
    • Make sure to keep all the screws in a cup or container so they don't get lost.
  2. Nerf N-Strike Maverick Trigger Repair: étape 2, image 1 de 2 Nerf N-Strike Maverick Trigger Repair: étape 2, image 2 de 2
    • After removing all of the screws, slowly lift the gray top left piece.
    • The other side of the top left piece can also be taken off.
  3. Nerf N-Strike Maverick Trigger Repair: étape 3, image 1 de 1
    • Remove the top left screw.
  4. Nerf N-Strike Maverick Trigger Repair: étape 4, image 1 de 2 Nerf N-Strike Maverick Trigger Repair: étape 4, image 2 de 2
    • While holding the Maverick down slowly lift the outer shell.
    • Make sure the orientation of the Maverick matches the picture shown.
  5. Nerf N-Strike Maverick Trigger Repair: étape 5, image 1 de 2 Nerf N-Strike Maverick Trigger Repair: étape 5, image 2 de 2
    • Remove the screw holding the trigger to the body.
    • When screwing everything back together, remember to re hook the trigger spring.
  6. Nerf N-Strike Maverick Trigger Repair: étape 6, image 1 de 3 Nerf N-Strike Maverick Trigger Repair: étape 6, image 2 de 3 Nerf N-Strike Maverick Trigger Repair: étape 6, image 3 de 3
    • Check the inner chassis around the trigger area. Make sure the springs and parts can move freely.
    • If a part is broken, a replacement will need to be bought or taken from another Maverick.
  7. Nerf N-Strike Maverick Trigger Repair: étape 7, image 1 de 2 Nerf N-Strike Maverick Trigger Repair: étape 7, image 2 de 2
    • After examining and fixing the chassis, screw the trigger back onto the body.
    • Hook the upper spring to the metal rod.
  8. Nerf N-Strike Maverick Trigger Repair: étape 8, image 1 de 3 Nerf N-Strike Maverick Trigger Repair: étape 8, image 2 de 3 Nerf N-Strike Maverick Trigger Repair: étape 8, image 3 de 3
    • Replace the outer shell of the Maverick and the top left screw.
    • When reattaching the outer shell, make sure to hold the top left piece as shown in the first picture. This ensures that the spring remains connected to the rod.
    • Screw the top left piece back onto the Maverick.
    • Replace the 10 screws on the Maverick.
Ligne d'arrivée
David Lim
Membre depuis le 09/27/15
110 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 10-3, Green Fall 2015 Membre de l'équipe Cal Poly, Team 10-3, Green Fall 2015
CPSU-GREEN-F15S10G3
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 17
Total : 2,216
