Introduction
The Barrel is the part of the gun that the dart exits. If it is badly cracked or clogged with dirt, it may block the dart from leaving. By using this guide, the barrel can be accessed for cleaning or replacement.
Ce dont vous avez besoin
Pull slide back.
Pull backwards on release buttons and slide magazine out.
Push slide back forward and pull trigger.
Use the Phillips #0 Screwdriver to remove these 9 screws.
All screws marked in red are 9.6 mm Phillips #0 screws.
Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
Pull slide back to reveal more screws.
Remove these 2 screws.
Push slide forward.
Pull trigger to release compression of the main spring.
Screws are 9.6 mm Phillips #0.
Remove the screws on the plunger cap.
Tug the plunger cap off.
Remove the 2 screws on the slide.
Pull the remaining half of the plunger out the back of the gun.
6 autres ont terminé cette réparation.
