Introduction
This repair should rectify weak fire or if the blaster doesn't fire at all. A screwdriver with a long shaft will be needed to get to all of the screws. Also watch out for any small parts that may come apart and fall out as you're working on the device.
Ce dont vous avez besoin
Start by taking out all of the screws for the casing of the gun. Using the PH #00 screwdriver, unscrew all four 1.3-cm screws in the pump.
Presque terminé !
