Aller au contenu principal
Nest Cam Mic Cable Replacement
Ce dont vous avez besoin
  1. Nest Cam Mic Cable Replacement, Mic Cable: étape 1, image 1 de 1
    • Remove the four 6 mm screws from the back panel with the J000 Phillips head screwdriver.
    • We suggest designated areas to keep track of all screws.
  2. Nest Cam Mic Cable Replacement: étape 2, image 1 de 3 Nest Cam Mic Cable Replacement: étape 2, image 2 de 3 Nest Cam Mic Cable Replacement: étape 2, image 3 de 3
    • Open the back panel completely to expose the inside of the Nest Cam.
    • Using the tweezers, disconnect the red and black mic cable from the motherboard.
  3. Nest Cam Mic Cable Replacement: étape 3, image 1 de 1
    • Holding the back panel firmly, use a spudger to pry off the small plastic panel holding the mic cable in place.
    • Use a heat gun to melt the glue keeping the mic cable in place and then remove it.
    • During reassembly this plastic piece may need to be glued back on to ensure the mic cable stays in place on the back panel.
Jade Weiss
Membre depuis le 02/24/16
662 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 1-1, Leahy Spring 2016 Membre de l'équipe USF Tampa, Team 1-1, Leahy Spring 2016
USFT-LEAHY-S16S1G1
7 membres
10 tutoriels rédigés
3 commentaires
Thank you for this look inside the device. In the Nest settings there is a way to turn off the microphone, but anyone with access can turn it back on. I'm going to use this guide to unplug the microphone and permanently (but reversibly) disable it.
Bruce MacDonald - Réponse
Yes, by accessing the settings either via the app, or the website. Device options will all you to control the mic recording, or notifications if you just don't want to know when it picks up audio. Each app has its own settings on my devices, I think, but don't quote me on that one.
Be He - Réponse
Good job.
Do you have any idea if the cam doesn't restart?
Thanks.
Summer
summer - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 24
Total : 3,679
