Aller au contenu principal
Nest Cam Outdoor S Battery Replacement
Ce dont vous avez besoin
  1. Nest Cam Outdoor S Battery Replacement, Plastic Camera Cover: étape 1, image 1 de 2 Nest Cam Outdoor S Battery Replacement, Plastic Camera Cover: étape 1, image 2 de 2
    • Wedge a spudger between the black front panel and the white outer shell.
    • Slide the spudger around the edge of the panel to pop it off.
  2. Nest Cam Outdoor S Battery Replacement: étape 2, image 1 de 1
    • Remove the four small screws from the plastic camera cover.
  3. Nest Cam Outdoor S Battery Replacement: étape 3, image 1 de 1
    • Disconnect the microphone cable to separate the motherboard from the main camera unit.
  4. Nest Cam Outdoor S Battery Replacement: étape 4, image 1 de 2 Nest Cam Outdoor S Battery Replacement: étape 4, image 2 de 2
    • Remove the plastic camera cover from the device.
  5. Nest Cam Outdoor S Battery Replacement, Battery: étape 5, image 1 de 2 Nest Cam Outdoor S Battery Replacement, Battery: étape 5, image 2 de 2
    • Wedge a nylon spudger between the white outer shell and the battery.
    • Slowly pull the battery away from the plastic camera cover.
    • The battery is only held on with glue.
Phelix Gaudette
Membre depuis le 10/28/21
275 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021 Membre de l'équipe UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G6
2 membres
4 tutoriels rédigés
3 commentaires
Do you have the P/N of the battery??
Richard K Yabuki - Réponse
Where to buy a replacement battery?
Ted McKenna - Réponse
I believe the battery model is GS24 (3.65V, 600 mAh/21.9Wh).
I also saw this on the battery
GPN: G823-00181-01
Dung Huynh - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 50
30 derniers jours : 227
Total : 6,907
