Aller au contenu principal
Nest Cam Outdoor S Motherboard Replacement
Ce dont vous avez besoin
  1. Nest Cam Outdoor S Motherboard Replacement, Plastic Camera Cover: étape 1, image 1 de 2 Nest Cam Outdoor S Motherboard Replacement, Plastic Camera Cover: étape 1, image 2 de 2
    • Wedge a spudger between the black front panel and the white outer shell.
    • Slide the spudger around the edge of the panel to pop it off.
  2. Nest Cam Outdoor S Motherboard Replacement: étape 2, image 1 de 1
    • Remove the four small screws from the plastic camera cover.
  3. Nest Cam Outdoor S Motherboard Replacement: étape 3, image 1 de 1
    • Disconnect the microphone cable to separate the motherboard from the main camera unit.
  4. Nest Cam Outdoor S Motherboard Replacement: étape 4, image 1 de 2 Nest Cam Outdoor S Motherboard Replacement: étape 4, image 2 de 2
    • Remove the plastic camera cover from the device.
  5. Nest Cam Outdoor S Motherboard Replacement, Motherboard: étape 5, image 1 de 1
    • Pry the plastic cover away from the motherboard at the plastic clips using a spudger.
  6. Nest Cam Outdoor S Motherboard Replacement: étape 6, image 1 de 1
    • Remove the four mounting screws from the motherboard.
  7. Nest Cam Outdoor S Motherboard Replacement: étape 7, image 1 de 1
    • Disconnect the yellow camera cable from the motherboard.
    • Remove the motherboard from the device.
Skylar DeVoe
Membre depuis le 10/28/21
235 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021 Membre de l'équipe UMass Dartmouth, Team 4-6, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G6
2 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 4
Total : 384
