Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This guide is used to replace the camera lens of the Nest Dropcam Pro. Make sure the device is unplugged before opening.
Pièces
Aucune pièce spécifiée.
  1. Press in the mounting clips on each side of the case to remove the camera from the mount.
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
  2. Using a Philips #0 screwdriver, remove the four 3 mm screws. Using a Philips #0 screwdriver, remove the four 3 mm screws.
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
  3. Lift the front of the case slowly, as there is an antenna cable attached to the motherboard. Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
  4. Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case. Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
    • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
  5. Pull the motherboard away from the back case. Unplug the red and black cable connecting the motherboard to the back case.
    • Pull the motherboard away from the back case.
    • Unplug the red and black cable connecting the motherboard to the back case.
  6. Using a Philips #0 screwdriver, remove the four 2 mm screws. Using a Philips #0 screwdriver, remove the four 2 mm screws.
    • Using a Philips #0 screwdriver, remove the four 2 mm screws.
  7. Lift the lens and LED assembly away from the motherboard. Unplug the yellow and white cable from the motherboard.
    • Lift the lens and LED assembly away from the motherboard.
    • Unplug the yellow and white cable from the motherboard.
  8. Using a Philips #0 screwdriver, remove the four 2 mm screws. Using a Philips #0 screwdriver, remove the four 2 mm screws.
  9. Peel off the paper seal holding the Lens and LEDs together. Disconnect the red and white wire from the bottom board. Disconnect the red and white wire from the bottom board.
    • Peel off the paper seal holding the Lens and LEDs together.
    • Disconnect the red and white wire from the bottom board.
  10. Lift up the foam cover to reveal a second screw underneath. Using a Philips #0 screwdriver, remove the two 3 mm screws.
    • Lift up the foam cover to reveal a second screw underneath.
    • Using a Philips #0 screwdriver, remove the two 3 mm screws.
  11. With the screws gone, lift the camera lens away from the remaining components.
    • With the screws gone, lift the camera lens away from the remaining components.
2 autre(s) ont terminé cette réparation.
David Foens
Membre depuis le 03/09/2015
839 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 15-4, Blackwell Fall 2015 Membre de l'équipe USF Tampa, Team 15-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G4
3 membres
12 tutoriels rédigés
Where do you get replacement lens?
Jim Fischer - Réponse
good morning , is there any store on the USA where i can send my drop camera ti get fix? it fell and doesn't want to broadcast any image.
andres - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 25
Total : 2,372
