Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This guide is needed to replace the Micro-USB port if the Nest Dropcam Pro is plugged in but not receiving power. Make sure the device is unplugged before opening.
  1. Press in the mounting clips on each side of the case to remove the camera from the mount.
    • Press in the mounting clips on each side of the case to remove the camera from the mount.
  2. Using a Philips #0 screwdriver, remove the four 3 mm screws. Using a Philips #0 screwdriver, remove the four 3 mm screws.
    • Using a Philips #0 screwdriver, remove the four 3 mm screws.
  3. Lift the front of the case slowly, as there is an antenna cable attached to the motherboard. Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
    • Lift the front of the case slowly, as there is an antenna cable attached to the motherboard.
    • Carefully disconnect the antenna cable from the motherboard. You will feel this cable "pop" out of place when disconnected.
  4. Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case. Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
    • Insert a spudger tool under the micro-USB port and lift to separate the motherboard from the back case.
  5. Pull the motherboard away from the back case. Unplug the red and black cable connecting the motherboard to the back case.
    • Pull the motherboard away from the back case.
    • Unplug the red and black cable connecting the motherboard to the back case.
  6. Using a Philips #0 screwdriver, remove the four 2 mm screws. Using a Philips #0 screwdriver, remove the four 2 mm screws.
    • Using a Philips #0 screwdriver, remove the four 2 mm screws.
  7. Lift the lens and LED assembly away from the motherboard. Unplug the yellow and white cable from the motherboard.
    • Lift the lens and LED assembly away from the motherboard.
    • Unplug the yellow and white cable from the motherboard.
  8. Using a soldering station and desoldering braid, desolder the four points surrounding the Micro-USB port. Lift the Micro-USB port away from the motherboard.
    • Using a soldering station and desoldering braid, desolder the four points surrounding the Micro-USB port.
    • Lift the Micro-USB port away from the motherboard.
4 autre(s) ont terminé cette réparation.
David Foens
Membre depuis le 03/09/2015
839 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 15-4, Blackwell Fall 2015 Membre de l'équipe USF Tampa, Team 15-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G4
3 membres
12 tutoriels rédigés
I don't have the soldering tools but I used lazerbond to reattach the old port. I hope all the conductors are touching their counter parts. I haven't plugged it back in yet. Wish me luck.
Kreschendalyn Backus - Réponse
Did it work for you?
Michael Candy -
Where can you order the micro-usb charge port for this cam?
Danny Acevedo - Réponse
Not sure where you get them but according to one site it uses a Micro USB 2.0 Type B Receptacle.
https://bit.ly/2Kg01z6
Debbie - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 33
Total : 4,186
