Introduction
The replacement of the LCD screen is not difficult. The tools need to replace it are the plastic opening tools.
Ce dont vous avez besoin
Grasp the display's metal outer ring with your fingers and pull directly away from the wall.
Turn the display over.
Remove the four 6 mm screws from the back of the display using a Phillips #0 screwdriver.
Pinch the gray 20-pin connector with your fingers and pull directly away from the display.
Locate the blue pull tab at the end of the ribbon which says, "1. Pull".
Grasp the tab with your fingers and pull directly away from the motherboard.
Outil utilisé dans cette étape :Tweezers$4.99
Locate the blue tab which says, "2. Pull".
Use tweezers to pull the battery up and away from the display.
Locate the blue tab which says "3 unplug".
Grasp the battery with your fingers. Pull gently directly away from the display to unplug the battery from the motherboard.
Grasp the battery with your fingers and pull directly away from motherboard to separate the battery from the display.
Remove the four 3mm screws with a #0 Phillips screwdriver.
Remove the one 4mm screw located at the edge of the auto-away sensor. Use a #0 Phillips screwdriver.
Lift the auto-away sensor from motherboard using tweezers.
Peel the copper foil gently from the EMI shield.
Remove one 4 mm screw from the motherboard using a #0 Phillips screwdriver.
Remove the EMI shield from the motherboard using the plastic opening tools.
Unsnap the LCD ribbon from the motherboard gently using the tweezers.
Locate the black tabs that hold the display to the motherboard.
Push the black tabs gently away from the motherboard using the plastic opening tools.
Push the crescent shape bottom of the display away from the plastic frame using the plastic opening tools.
Pry the LCD screen gently from the plastic frame using the plastic opening tools.
Pull the LCD screen away from the plastic frame gently using your fingers.
8 autres ont terminé cette réparation.
5 commentaires de tutoriel
Thank you for providing this tutorial. My dog, not making this up, knocked my nest off the wall. Where can I purchase the replacement green itself and the plastic opening tools you used throughout the repair? This will be my first time on something like this, but with your guide I should have a decent shot at not screwing it up.
Skip step 12. There is no reason to remove the EMI shield.
Where can you get the replacement lcd screen for gen 2 nest learning thermostat?
