Introduction
This guide will explain the process of removing the Sync button on the device. It is important to remember that if you are having connection problems it could be a simple hardware problem. To best use this guide the Phillips 00 screwdriver is recommended. The Phillips 000 or 0 may work as well, please note that the smaller the screwdriver the higher chances of stripping the screw. It is also recommended to have a plastic opening tool (blue) to gently pull the device apart and a bowl or container to keep the small and easily lost screws in.
Ce dont vous avez besoin
Unscrew the two 3.0 mm Phillips #00 screws on the bottom of the camera.
Open the battery compartment on the bottom by pushing the switch marked in orange to the side and pushing the bottom of the camera back, sliding it open.
Unscrew the two 3.0 mm Phillips #00 screws on either side of the SYNC button.
Remove the white plastic covering.
Remove the white SYNC button.
