Aller au contenu principal
NeuTab Air7 Battery Replacement
Ce dont vous avez besoin
  1. NeuTab Air7 Battery Replacement, Back Cover: étape 1, image 1 de 3 NeuTab Air7 Battery Replacement, Back Cover: étape 1, image 2 de 3 NeuTab Air7 Battery Replacement, Back Cover: étape 1, image 3 de 3
    • Ensure your device is powered off before you begin.
    • Use the opening tool to gently pry the back cover off of the tablet, running it along the perimeter of the device.
  2. NeuTab Air7 Battery Replacement, Battery: étape 2, image 1 de 2 NeuTab Air7 Battery Replacement, Battery: étape 2, image 2 de 2
    • The following instructions require soldering, which can risk burn injuries as well as component damage for those novice in the skill. Tread with caution.
    • For a guide on how to solder, click here.
    • Remove any adhesive tape that is holding the wires protruding from the battery down.
    • De-solder the red and black wire ends that connect the battery to the motherboard.
  3. NeuTab Air7 Battery Replacement: étape 3, image 1 de 2 NeuTab Air7 Battery Replacement: étape 3, image 2 de 2
    • Using metal tools can cause damage to the battery and potentially create a fire hazard. ESD safe tools are recommended for this operation.
    • Wedge a plastic or nylon spudger underneath the battery, moving it back and forth to separate it from the device.
    • Remove the battery.
Jason Soares
Membre depuis le 10/29/23
532 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023 Membre de l'équipe UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 174
