Aller au contenu principal
NeuTab Air7 Speaker Replacement
Ce dont vous avez besoin
  1. NeuTab Air7 Speaker Replacement, Back Cover: étape 1, image 1 de 3 NeuTab Air7 Speaker Replacement, Back Cover: étape 1, image 2 de 3 NeuTab Air7 Speaker Replacement, Back Cover: étape 1, image 3 de 3
    • Ensure your device is powered off before you begin.
    • Use the opening tool to gently pry the back cover off of the tablet, running it along the perimeter of the device.
  2. NeuTab Air7 Speaker Replacement, Speaker: étape 2, image 1 de 2 NeuTab Air7 Speaker Replacement, Speaker: étape 2, image 2 de 2
    • The following instructions require soldiering, which can risk burn injuries as well as component damage for those novice in the skill. Tread with caution.
    • For a guide on how to solder, click here.
    • De-solder the red and black wire ends that connect the speaker to the motherboard.
  3. NeuTab Air7 Speaker Replacement: étape 3, image 1 de 3 NeuTab Air7 Speaker Replacement: étape 3, image 2 de 3 NeuTab Air7 Speaker Replacement: étape 3, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the two 0.8 mm screws holding the cover of the speaker in place.
    • Remove the cover and the speaker.
Jason Soares
Membre depuis le 10/29/23
532 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023 Membre de l'équipe UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 94
