Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
In this guide we will be removing the motherboard. The motherboard is a circuit board that contains the main components of the tablet. It connects the main accessories like the camera, battery, and screen. By following this guide, you will be able to successfully replace your motherboard on your NeuTab N7 Pro Tablet.
  1. Power off you device before beginning disassembly.
    • Power off you device before beginning disassembly.
    • Insert plastic opening tool and pry back case away from the device, slowly moving the plastic opening tool along the device.
  2. Use a soldering gun to separate all soldered wires from the motherboard. For a complete guide on how to solder, click here. For a complete guide on how to solder, click here.
    • Use a soldering gun to separate all soldered wires from the motherboard.
    • For a complete guide on how to solder, click here.
  3. OUVRIR TOUS LES ONGLETS
    Kits de mise à jour de RAM pour Mac
    Voir les kits
    Assez de RAM
    pour ouvrir tous les onglets
    Voir les kits
  4. Use a spudger to carefully release the tabs on the three ZIF connectors securing the ribbon cables to the motherboard.
    • Use a spudger to carefully release the tabs on the three ZIF connectors securing the ribbon cables to the motherboard.
    • Carefully pull the ribbons out with tweezers.
  5. Use Phillips #J0 Screwdriver to remove three 1mm screws from the motherboard Use Phillips #J0 Screwdriver to remove three 1mm screws from the motherboard Use Phillips #J0 Screwdriver to remove three 1mm screws from the motherboard
    • Use Phillips #J0 Screwdriver to remove three 1mm screws from the motherboard
Travis McLean
Membre depuis le 09/02/2016
322 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 7-1, Cheng Spring 2016 Membre de l'équipe USF Tampa, Team 7-1, Cheng Spring 2016
USFT-CHENG-S16S7G1
3 membres
10 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 480
