Aller au contenu principal
Newport e500 Pneumatic Box Disassembly
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
Ce dont vous avez besoin
  1. Newport e500 Pneumatic Box Disassembly, Newport e500 Top Cover Disassembly: étape 1, image 1 de 1
    • Place device so that the top cover is facing you.
    • Open the top cover.
  2. Newport e500 Pneumatic Box Disassembly: étape 2, image 1 de 1
    • Remove the four hex nuts and lock washers (two at each hinge) that secure the cover to the hinges on the left side of the pneumatic box.
  3. Newport e500 Pneumatic Box Disassembly: étape 3, image 1 de 1
    • Remove the cover and set aside. Retain hardware for re-assembly.
  4. Newport e500 Pneumatic Box Disassembly, Newport e500 Left Side Panel Disassembly: étape 4, image 1 de 1
    • Carefully place the GDU on its right side with the front of the GDU facing you.
    • Remove the three screws and washers at the top edge of the left side panel.
  5. Newport e500 Pneumatic Box Disassembly: étape 5, image 1 de 1
    • Remove the two screws and washers from the underside of the left side panel.
  6. Newport e500 Pneumatic Box Disassembly: étape 6, image 1 de 1
    • Remove the left side panel. Retain hardware for re-assembly.
  7. Newport e500 Pneumatic Box Disassembly, Newport e500 Right Side Panel Disassembly: étape 7, image 1 de 1
    • Carefully place the GDU on its left side.
  8. Newport e500 Pneumatic Box Disassembly: étape 8, image 1 de 1
    • Remove the four screws and washers at the top edge of the right side panel.
  9. Newport e500 Pneumatic Box Disassembly: étape 9, image 1 de 1
    • Remove the two screws and washers from the underside of the right side panel.
  10. Newport e500 Pneumatic Box Disassembly: étape 10, image 1 de 1
    • Remove the right side panel. Retain hardware for re-assembly.
  11. Newport e500 Pneumatic Box Disassembly, Newport e500 Flow Sensor Cover Disassembly: étape 11, image 1 de 1
    • Remove the three screws and washers that secure the flow sensor cover to the pneumatic box assembly. Retain the hardware for re-assembly.
  12. Newport e500 Pneumatic Box Disassembly: étape 12, image 1 de 1
    • Remove the flow sensor cover.
  13. Newport e500 Pneumatic Box Disassembly, Newport e500 Exhalation Module Disassembly: étape 13, image 1 de 1
    • Pull up and remove the flexible rubber exhalation outlet boot (push fit).
  14. Newport e500 Pneumatic Box Disassembly: étape 14, image 1 de 1
    • Disconnect the tubes from both sides of the flow sensor and the two tubes from the exhalation valve.
  15. Newport e500 Pneumatic Box Disassembly: étape 15, image 1 de 1
    • Pull the exhalation module straight up to remove it from the GDU.
  16. Newport e500 Pneumatic Box Disassembly, Newport e500 Pneumatic Box Disassembly: étape 16, image 1 de 1
    • Remove the two screws and washers (back corners), one screw and washer (exhalation module support bracket), and two standoffs and washers (front corners) that secure the pneumatic (upper) box assembly to the electronic box assembly. Lift the Pneumatics Box and carefully tilt to one side.
  17. Newport e500 Pneumatic Box Disassembly: étape 17, image 1 de 1
    • Remove cables from connectors J1, J2, J3, J4, J5, and J6 on the main PCB (4 connectors are not shown due to being blocked by the side panel). Note the position of these connectors for re-assembly.
  18. Newport e500 Pneumatic Box Disassembly: étape 18, image 1 de 1
    • If not already detached, remove the heater cables from J5 and J6 on the DC-DC power supply PCB.
Jared McMullen
Membre depuis le 05/02/18
473 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team S7-G16, Paton Spring 2020 Membre de l'équipe Cal Poly, Team S7-G16, Paton Spring 2020
CPSU-PATON-S20S7G16
3 membres
13 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 11
Total : 101
