Introduction
This step of removing the power supply needs to be done carefully. It is important to note that in no instance are you able to touch the transformer on the power supply. This could lead to permanent damage. For more information go to page 75 of the service manual.
Ce dont vous avez besoin
Place device so that the top cover is facing you.
Open the top cover.
Carefully place the GDU on its right side with the front of the GDU facing you.
Remove the three screws and washers at the top edge of the left side panel.
Carefully place the GDU on its left side.
Remove the three screws and washers that secure the flow sensor cover to the pneumatic box assembly. Retain the hardware for re-assembly.
Remove the two screws and washers (back corners), one screw and washer (exhalation module support bracket), and two standoffs and washers (front corners) that secure the pneumatic (upper) box assembly to the electronic box assembly. Lift the Pneumatics Box and carefully tilt to one side.
From the underside of the electronics box assembly, remove the four screws and lock washers that secure the power supply to the box assembly.
