Aller au contenu principal
NexiGo NS32 Battery Replacement
Ce dont vous avez besoin
  1. NexiGo NS32 Battery Replacement, Rear Case: étape 1, image 1 de 1
    • Orient the controller so that it is face down.
  2. NexiGo NS32 Battery Replacement: étape 2, image 1 de 2 NexiGo NS32 Battery Replacement: étape 2, image 2 de 2
    • Remove the eight 9 mm Phillips screws that secure the rear case.
  3. NexiGo NS32 Battery Replacement: étape 3, image 1 de 1
    • Lift the rear case up and off.
    • You may need to use an opening tool to help release the rear case, but avoid using excessive force so you don't damage the controller.
  4. NexiGo NS32 Battery Replacement, Battery: étape 4, image 1 de 2 NexiGo NS32 Battery Replacement, Battery: étape 4, image 2 de 2
    • Grip the white battery connector and pull it directly out of its motherboard socket.
    • This may require some force, as the connectors are secured with a bit of adhesive. If you're having trouble with disconnection, apply some high-concentration isopropyl alcohol to the adhesive to loosen it.
    • Do not pull on the wires.
  5. NexiGo NS32 Battery Replacement: étape 5, image 1 de 3 NexiGo NS32 Battery Replacement: étape 5, image 2 de 3 NexiGo NS32 Battery Replacement: étape 5, image 3 de 3
    • Lift the battery up and out.
    • Take care not to bend or puncture the battery as you remove it.
Matthew Nguyen
Membre depuis le 01/29/24
235 Réputation
1 tutoriel rédigé
Équipe
Austin Community College, Team 18-3, Watkins Spring 2024 Membre de l'équipe Austin Community College, Team 18-3, Watkins Spring 2024
AUSTINCC-WATKINS-S24S18G3
4 membres
8 tutoriels rédigés
Un commentaire
Do you know what model battery I would need to buy to replace the original?
Jack Dunne - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 142
