Introduction
The motherboard is the brain of the device. When all else fails to fix a problem, the motherboard needs to be replaced. This guide will show you how to replace the motherboard. First you will remove the battery and then the motherboard. The most difficult part will be removing the back cover so please follow the steps carefully. The entire process is moderately difficult and will take you approximately 30 minutes to complete.
Ce dont vous avez besoin
With the tip of the thin metal spudger in place, use a prying motion to work the spudger down the side to the corner of the device.
Locate and remove the yellow cellophane tape from the display assembly ribbon cable ZIF connector.
2 autres ont terminé cette réparation.
