Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Pièces
Aucune pièce spécifiée.
  1. Turn the device over so it is upside-down.
    • Turn the device over so it is upside-down.
  2. Unscrew the 4 screws closest to the screen.
    • Unscrew the 4 screws closest to the screen.
  3. Flip over the device so it is right side up.
    • Flip over the device so it is right side up.
  4. Unscrew the 2 screws on the top of the device, next to the docking plug.
    • Unscrew the 2 screws on the top of the device, next to the docking plug.
  5. Fix Kits pour écrans LCD d'iPhone
    L'option économique couverte par notre garantie à vie.
    Acheter des kits
    Réduisez les coûts de réparation et non pas la qualité.
    Acheter des kits
  6. Take off top piece by using slight force and pulling off.
    • Take off top piece by using slight force and pulling off.
  7. Unscrew the button board with smaller screwdriver.
    • Unscrew the button board with smaller screwdriver.
  8. Lift off the button board.
    • Lift off the button board.
  9. Unscrew all visible of the screws on the black logic board cover with the larger screwdriver.
    • Unscrew all visible of the screws on the black logic board cover with the larger screwdriver.
  10. Lift the screen vertically straight up.
    • Lift the screen vertically straight up.
    • As you do this the logic board should move off with it.
  11. Flip the screen and the logic board over to the right side.
    • Flip the screen and the logic board over to the right side.
  12. Pull out the white plug that goes from the speakers to the logic board.
    • Pull out the white plug that goes from the speakers to the logic board.
    • Then plug back in making sure it is completely connected.
Michelle Read
Membre depuis le 26/09/2012
1 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 7-50, Forte Fall 2012 Membre de l'équipe Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 membres
7 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 307
