Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Nexus 10 Front Facing Camera Replacement
Ce dont vous avez besoin
    1. Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: étape 1, image 1 de 3 Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: étape 1, image 2 de 3 Nexus 10 Front Facing Camera Replacement, Front-Facing Camera: étape 1, image 3 de 3
      • Remove the plastic cover located on the back of the device by prying off one side of the cover with a plastic opening device and peeling it back.
      Demander à FixBot
      Ajouter un commentaire
    2. Nexus 10 Front Facing Camera Replacement: étape 2, image 1 de 3 Nexus 10 Front Facing Camera Replacement: étape 2, image 2 de 3 Nexus 10 Front Facing Camera Replacement: étape 2, image 3 de 3
      • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
      • Pull the the plastic backing off the display assembly using your hands.
      • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
      Demander à FixBot
    3. Nexus 10 Front Facing Camera Replacement: étape 3, image 1 de 3 Nexus 10 Front Facing Camera Replacement: étape 3, image 2 de 3 Nexus 10 Front Facing Camera Replacement: étape 3, image 3 de 3
      • Lift latch on front-facing camera connector.
      • Pull the connector toward the top of the device and remove the front-facing camera.
      Demander à FixBot
Benjamin Troller
Membre depuis le 04/11/16
2 239 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 34-18, Maness Spring 2016 Membre de l'équipe Cal Poly, Team 34-18, Maness Spring 2016
CPSU-MANESS-S16S34G18
4 membres
60 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 26
30 derniers jours : 60
Total : 996
