Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Nexus 10 Headphone Jack Replacement
Ce dont vous avez besoin
    1. Nexus 10 Headphone Jack Replacement, Battery: étape 1, image 1 de 3 Nexus 10 Headphone Jack Replacement, Battery: étape 1, image 2 de 3 Nexus 10 Headphone Jack Replacement, Battery: étape 1, image 3 de 3
      • Using a plastic opening tool, remove the thin plastic cover from back of the tablet by prying up from its small tab.
      Demander à FixBot
      Ajouter un commentaire
    2. Nexus 10 Headphone Jack Replacement: étape 2, image 1 de 1
      • Remove the five 2mm screws on the back of the device using a PH00 screwdriver.
      Demander à FixBot
    3. Nexus 10 Headphone Jack Replacement: étape 3, image 1 de 3 Nexus 10 Headphone Jack Replacement: étape 3, image 2 de 3 Nexus 10 Headphone Jack Replacement: étape 3, image 3 de 3
      • Pry the device apart by inserting a plastic opening tool in the seam between the plastic backing and display assembly. Use the tool to unclip the plastic tabs in between the backing and the display.
      • Pull the the plastic backing off the display assembly using your hands.
      • Do not do this step with only your hands. You will require a significant amount of force to separate the device.
      Demander à FixBot
    4. Nexus 10 Headphone Jack Replacement: étape 4, image 1 de 3 Nexus 10 Headphone Jack Replacement: étape 4, image 2 de 3 Nexus 10 Headphone Jack Replacement: étape 4, image 3 de 3
      • Detach the three connector ribbons passing over the battery using the plastic opening tool.
      Demander à FixBot
    5. Nexus 10 Headphone Jack Replacement: étape 5, image 1 de 1
      • Remove the twelve 2mm screws around the perimeter of the battery with a PH00 screwdriver.
      Demander à FixBot
    6. Nexus 10 Headphone Jack Replacement: étape 6, image 1 de 2 Nexus 10 Headphone Jack Replacement: étape 6, image 2 de 2
      • Disconnect the battery by lifting it upward and pulling it away from the connector.
      Demander à FixBot
    1. Nexus 10 Headphone Jack Replacement, Headphone Jack: étape 7, image 1 de 1
      • Remove one screw on the logic board with a PH00 screwdriver.
      Demander à FixBot
    2. Nexus 10 Headphone Jack Replacement: étape 8, image 1 de 3 Nexus 10 Headphone Jack Replacement: étape 8, image 2 de 3 Nexus 10 Headphone Jack Replacement: étape 8, image 3 de 3
      • Disconnect right speaker connector ribbon from logic board.
      • Lift the speaker out by pulling up on its corner.
      Demander à FixBot
    3. Nexus 10 Headphone Jack Replacement: étape 9, image 1 de 3 Nexus 10 Headphone Jack Replacement: étape 9, image 2 de 3 Nexus 10 Headphone Jack Replacement: étape 9, image 3 de 3
      • Disconnect connectors around the perimeter of the motherboard.
      Demander à FixBot
    4. Nexus 10 Headphone Jack Replacement: étape 10, image 1 de 2 Nexus 10 Headphone Jack Replacement: étape 10, image 2 de 2
      • Remove motherboard by gently pulling upward under its corner.
      Demander à FixBot
    5. Nexus 10 Headphone Jack Replacement: étape 11, image 1 de 1
      • Remove the three 2mm screws along the right side of the device using a PH00 screwdriver.
      Demander à FixBot
    6. Nexus 10 Headphone Jack Replacement: étape 12, image 1 de 2 Nexus 10 Headphone Jack Replacement: étape 12, image 2 de 2
      • Unseat the small vibrator motor by gently applying upward pressure with a spudger.
      Demander à FixBot
    7. Nexus 10 Headphone Jack Replacement: étape 13, image 1 de 2 Nexus 10 Headphone Jack Replacement: étape 13, image 2 de 2
      • Lift the assembly by gently applying upward pressure with the spudger on the assembly.
      Demander à FixBot
    8. Nexus 10 Headphone Jack Replacement: étape 14, image 1 de 2 Nexus 10 Headphone Jack Replacement: étape 14, image 2 de 2
      • Gently pull battery-audio jack-USB assembly upward, detaching it from its adhesive.
      Demander à FixBot
Benjamin Troller
Membre depuis le 04/11/16
2 239 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 34-18, Maness Spring 2016 Membre de l'équipe Cal Poly, Team 34-18, Maness Spring 2016
CPSU-MANESS-S16S34G18
4 membres
60 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 29
30 derniers jours : 70
Total : 1,316
