Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This guide details the removal and installation of the external power and volume buttons located on the right edge of the back cover.
    • Power off the phone, by long-pressing the power button and touching Power off.
    • Remove the SIM tray using the SIM Card Eject Tool.
    • This step is required in order to remove the back case.
  1. Le kit d'outils Essentiel
    Les outils les plus utiles dans notre kit le plus compact.
    J'achète
    J'achète
  2. Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool. The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone. The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
    • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
    • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
  3. Holding the back case, gently push the power button in towards the center of the phone using a spudger. Holding the back case, gently push the power button in towards the center of the phone using a spudger.
    • Holding the back case, gently push the power button in towards the center of the phone using a spudger.
  4. To remove the volume button, push the button in towards the center of the phone using a spudger. To remove the volume button, push the button in towards the center of the phone using a spudger. To remove the volume button, push the button in towards the center of the phone using a spudger.
    • To remove the volume button, push the button in towards the center of the phone using a spudger.
16 autre(s) ont terminé cette réparation.
Kaitlyn Jones
Membre depuis le 27/01/2013
4 928 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 3-32, Amido Winter 2013 Membre de l'équipe Cal Poly, Team 3-32, Amido Winter 2013
CPSU-AMIDO-W13S3G32
4 membres
8 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 15
Total : 29,203
