Introduction
Use this guide to replace the rear-facing camera in your Nexus 5.
Use a plastic opening tool to free the clips on the top and each side of the back cover.
Remove the six 4.0 mm Phillips #00 screws that secure the midframe to the phone.
To replace the LCD screen and digitizer, remove the additional four 4.0mm daughterboard cover screws with the same screwdriver. You may have to pierce through clear adhesive material to remove them.
Use the flat end of a spudger to disconnect the rear-facing camera.
26 autres ont terminé cette réparation.
Un commentaire
In case anyone else was confused about the end like I was: you don't have to remove the old adhesive, just leave it and put the replacement directly on top of it. It worked just fine for me!
