Aller au contenu principal
Introduction
Use this guide to remove the rear panel of your Nexus 5X.
  1. Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone. Press in to eject the SIM card tray. Remove the SIM card tray.
    • Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
    • Press in to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place. Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel. Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
    • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
    • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
  3. Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel. Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel. Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
    • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
  4. Tilt the opening pick to lift the rear panel a little bit. There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
    • Tilt the opening pick to lift the rear panel a little bit.
    • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
    • Remove the rear panel.
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
26 autres ont terminé cette réparation.
Dominik Schnabelrauch
Membre depuis le 23/11/2016
125 778 Réputation
525 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
142 membres
16 768 tutoriels rédigés
Un commentaire
Bonjour,
Est-ce que vous arriveriez à m'indiquer l'espace disponible (en mm) entre le cache et la batterie svp?
Merci!
Lucas Marti - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 21
Total : 8,415
