Aller au contenu principal
Introduction
Use this guide to replace the rear case on your Nexus 6.
  1. Nexus 6 Rear Case Replacement, SIM Card: étape 1, image 1 de 1
    • With a SIM card eject tool (a paperclip will work as well), push down on the hole at the top of the phone until the SIM card holder releases. This should not take much pressure.
    • Remove the SIM card and the SIM card holder.
    • Lay out a soft cloth on your workspace to prevent scratching the screen in this and future steps.
    • Pry open the back casing using the soft plastic opening pick.
    • Be careful of the Power & Volume Key ribbon on the left side just next to the volume key. The ribbon is exposed and could be damaged with the opening tool.
    • Carefully pull the back casing apart from the rest of the phone with your hands. Because the casing is glued to the rest of the phone, this step may require some force. Don't be alarmed if the casing flexes a bit.
    • You may need an iOpener to loosen up the adhesive. Check out the Instructions iOpener for info on how to use it.
  2. Nexus 6 Rear Case Replacement: étape 3, image 1 de 1
    • Remove the twenty-two 2.3 mm T3 Torx screws with the T3 Torx Screwdriver.
  3. Nexus 6 Rear Case Replacement: étape 4, image 1 de 3 Nexus 6 Rear Case Replacement: étape 4, image 2 de 3 Nexus 6 Rear Case Replacement: étape 4, image 3 de 3
    • With tweezers, remove the rubber protector on the lower part of the phone.
    • Disconnect the battery connector by gently prying it straight up with a spudger, on the side opposite the cable.
    • Completely separate the battery side from the motherboard side by gently pulling the sides apart with your hands.
5 autres ont terminé cette réparation.
Marina Moore
Membre depuis le 13/01/2015
4 257 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 70-3, Forte Winter 2015 Membre de l'équipe Cal Poly, Team 70-3, Forte Winter 2015
CPSU-FORTE-W15S70G3
4 membres
30 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 14
Total : 4,722
